1 - 16 of 16 Posts
INDYPWR said:
ill give it a shot....10psi?
Speaking from extensive experience? j/k :p
In a blow-through setup, I've found that at 8 psi, the MAF is reading 4.8 Volts, which is getting very close to the maximum 5 Volts.
I'd say 10 psi is actually a very good guess.
Of course this also depends on the turbo.
You could have a turbo boosting 15 psi and flowing very little air or a turbo that will outflow the MAF capabilities at 5 psi.
~Alan
looking for another Supra
cause obviously i want to remove my maf. some shops said that the Maf can be removed when i get the extra pressure sensor harness with my e-manage. i figured the e-manage is like a mini aem ems so it should do it no problem. but SP said that i cant remove the maf with the e-manage. any inputs.
Now...Whitesupra94
~Alan
damn...only 8psi running blow through? then what happens?
What about if its in front of the turbo?
I may have to make adjustments on my plans then.
~Alan
see? you know im right.......lol:D
i will try your set-up and mount that maf before TB.
im just waiting for a few more parts and start the project..
Now...Whitesupra94
SPORTcoupe said:
Then you need bigger injectors and some kind of management.
~Alan
Assuming a V8 MAF, 525cc's, and AFC, hg, headstuds, what kind of boost can be run blowthrough?
Haven't tried it.
I figure the V8 MAF should be able to handle ~20 psi.
At these boost levels, I think it's safer to switch over to speed-density.
~Alan
King of the NA-T's
I ran low 20's psi through the Lex V8 AFM on my MKIII, made 440 rwhp. I didn't check what the frequency was, so I don't know how much more it can do. This was drawthrough fyi.
nice
stock ECU??
safc??
Now...Whitesupra94
SPORTcoupe said:
Haven't tried it.
~Alan
~20 psi blowthrough or before the turbo?
1 - 16 of 16 Posts
