ok ive read so many different hp #'s made on the stock rods.ive read over 900hp in magazine tha ive seen some hp #s in the 800's.i just want to know what hp range exactly can the rods be used to reliably without worrying about it bending?
+1Most seem to try not to push it past 700 with the stock rods for extended amounts of time. Sure you can make 1000whp on the stock rods, but it's a ticking time bomb.
Alex
I first started it at about 3500, but at 30psi the clutch would let go at 5600rpm. I think 3500 was probably a little too early because I did have a nitrous backfire. I think that is why you don't want it too early, among other reasons I am sure.ok... makes sense that you wouldn't want the shot to come on right at peak torque.
regarding WHEN though... i remember a thread not too long ago, discussing how torque affected the rods, and whether or not they are more likely to bend if the torque increased rapidly at lower rpms vs higher... is it a 'balancing act' then - you want the shot to hit before peak torque but not TOO early?
thanks again,
craig
alright... cool, thanks for the explanation.I first started it at about 3500, but at 30psi the clutch would let go at 5600rpm. I think 3500 was probably a little too early because I did have a nitrous backfire. I think that is why you don't want it too early, among other reasons I am sure.
