1 - 11 of 11 Posts
Hi,
About Limits with stock internals:
For 1/4 Mile, what the maximum recommended power without problems ?
and
For Track days, what the maximum recommended power without problem ?
Ricardo
Boost4fun
As far as the common opinion here goes the internals are good for roundabout 800hp. Everything beyond this would require reinforced internals to be on the safe side. Though there have been people dyno 1000hp on a stock shortblock but this is jeopardizing the luck..
In your case I wouldn´t be worried about improving your engine. Just ensure to have a large oil cooler in for track purposes and watch the oil and EG temperatures..
Gerd
How long do you want it to last?
Gerd
What the best Oil cooler for tracks ?
Boost4fun
At very least a 16 row would be helpful. Better off with a 19 row and utilize a thermostat in order to having the oil heated up in a reasonable time. W/O a thermostat it is taking very long until oil has reached it´s operation temp of at least 70-80°C.
About 16 row, it's possible to install at right side of bumper, behind the signal lights ?
P
800hp is as high as i would go with stock internals....but i had my block re-built before i hit that number
Boost4fun
Why not on the left side where the oil filter is located at? There you can also install it behind the turn signal. IMO the best place for it.
Yes, 16row should work.:)
Boost4fun
Setrab is a rather know brand here in Europe. As far as I know a good quality product.
1 - 11 of 11 Posts
