Fluidyne makes a couple.
Fluidyne Therm-Hx" "Parallel Flow" Heat Exchangers
Fluidyne Therm-Hx" "Parallel Flow" Heat Exchangers are the "Original" new innovation in Engine Oil Cooling.
The DB-30500 all-aluminum unit is track tested and is the choice of thousands of teams in all forms of racing including off-road, dirt track, short track and super speedway.
The compact design of the DB-30500 provides a significant performance advantage for alcohol burning midgets, sprints and stock cars as oil coolers will preheat and stabilize the engine oil.
The Therm-Hx" unit needs no air to cool your oil, just a portion of the hot water returning to the radiator and can be mounted in almost any axis for maximum versatility!
DB-30500 Specfications:
* 14 3/4" x 6 1/4" x 4 1/2"
* 80,000 BTU
* AN-12 oil fittings
* 3/4" NPT water fittings
* 1.0 qt. capacity
* 9 1/2 lbs dry weight
DB-30501 Specfications:
* 9" x 5 3/8" x 6 3/8"
* 60,000 BTU
* .8 qt. capacity
* 6 1/2 lbs dry weight
