THE NOTORIOUS BHP
Recently a friend of mine had a methanol kit do damage after car was parked on a down hill slant. Apparently this caused a siphon effect filling the intercooler which led to big problems. Im not sure if Josh has posted up here about this yet or if he even wants to. I will let the details of exactly what happened up to him. But I was just wondering if this ever happened to any members before with the trunk mounted tank, and if so whats the best way to insure it won't happen. I was about ready to get a kit but want to be sure this doesn't happen.
( Josh, if you rather I not even bring this up I will delete but im hoping to get feedback so that I can insure it won't possibly happen again )
Boost Junkie
My friend Supra400hptt had a similar problem. Luckily no damage though as he caught it. His methanol system relay went bad and filled his intercooler with 1 gallon of methonal.
Steve K.
feeding your habit
sounds like he forgot to install his check valve or he is using a pump that isn't a diapraghm type.
By the way, that isn't any kind of hurtin. Try sucking in a few tablespoons of water into one cylinder, now that's a hurtin. Bent rod kind of hurtin.
I ditched the progressive relay set up and just use a regular relay triggered by a rpm switch now. The siphoning is another issue and I haven't had that problem using the washer tank yet.
