MHG or stock HG?
1 - 8 of 8 Posts
Not ur jizz, not ur bizz
MHG would be t he obvious choice.
I am one of a smaller group on the forum that are ok with the stock HG at medium power levels, as long as its torqued up. However, even once I get tuned and am running 15psi, I will only use 94 octane, and I may upgrade my IC as well.
No way you will want a stock HG running 20 psi. Once youve bought a turbo upgrade, a MHG is small change.
was this called for?if you dont want to take off the head back for a long time..go with the MHG..if you liek changing head gaskets ..be our guest...make sure atleast invest in some arp studs or something
1 - 8 of 8 Posts
