Hi guys so I’m in the middle of downpipe/midpipe design and I’m at the point that I can decide how to merge them and where.
I was originally gonna fab it how the HKS twin kit used to come out of the box, with the downpipes merging together before the midpipe, leaving the rest of the system modular.
but now I’m considering moving the merge further back in the system, just before the catback, as Mr. Henderson has done on his monster. I can fab it either way if it makes a difference in my setup.
basics of my setup are 3.0L, 10:1, e85, big plenum, Kelford v202d cams,1700cc/twin 450’s, and twin GTX3071R Gen2. From the turbo 2” compressor outlets they merge to the 75mm/3” HKS Type-R fmic to 3” exit, up to my 4” transition to the 4” throttle body. The twin manifold is from suprastore and it has long runners to tial v-band entry flanges to each .82 tial housing. Maybe this is irrelevant to what I’m asking but just including these details anyway.
from each turbo are twin 3” downpipes. so my two questions are what’s the best location for the merge, and is a merge collector (that has the pinch) better than just a Y-pipe that transitions the two ? does it really matter ? I’d imagine I’d end up somewhere with 800+whp at least with my setup but idk…. ive read that the merge collectors like this are typically used at the end of NA big displacement longtubes. is the theory the same ?
either way I’d need to join to 3” pipes to a single 4”.
this one below i already have
they both have the same entry and exit dimensions but one is a merge collector and the other is simply a collector. if I’m overthinking it then let me know. Visually the merge collector (top picture) looks like a smoother transition but the pinch just before the 4” section has me curious. For NA use they mention the venturi effect being useful but would it just be a restriction on the post-turbo side of things ?
Thanks guys,
Mark
Thanks guys,
Mark
