41 - 60 of 569 Posts
I just got the box of goodies from SP, and im a little overwhelmed. The pinout list is insanely long. This wiring is going to be the end of me!!!
just gotta remember wiring is really really easy!! point a to point b. keep a diagram and TAKE YOUR TIME!! good luck and god speed my friend
Discussion Starter #45 (Edited)
Items I still need:
Red targa top
Coil cover (would like one with the front clear/cut out)
AC components (Everything but the compressor)
4 point camlock harnesses (2)
2 Nitrous bottles with mounting brackets, long braided line, and a Y adapter & two short lines to run two tanks
Aluminum battery box & circuit breaker
just the full race sticker alone got me scare,guys like me only dream to own one,,
good lo0king project man,keep up the good work;
Discussion Starter #49
Wow ...this thing is gonna be nice.
gosh I hope so lol
All the stickers are probably going to be removed. I am not a huge sticker fan. And I dont have a full race mani... the previous owner did.
Awesome build and cant wait to see more progress. Splitting the tails is new to me. Ive only ever thought/ done headlights!
97 HARD TOP
nice build man, your going to love that 80mm turbo. im running a gt4780 t6 frame. i personally think lag is over rated. i built mine just to have fun on the highway and man do i. gets kinda lonely always being in the front of the pack by yourself lol. youll see what i mean soon enough. look foward to updates
Discussion Starter #54 (Edited)
Alright... so the first real "snag" came up when i changed manifolds. Bottom line is the one i got was a custom piece built by someone who had some mods done that I didnt have. Unfortunately I didnt know this, so i figured it would work just fine on my motor... WRONG! lol
Took some time and a lot longer than any manifold install should, but she is finally on. I had to make some custom hardware because a standard M10 nut did not work. Also I had to source a step down stud because the hillbillies that did the head must have stripped a bolt and then just tapped it out to M12. So I bought a stud from an off road racing shop which has a stud that steps a M12 down to an M10 like the rest of my manifold studs. finally the guy who had this before me had a solid motor mount. I did not, so I had to grind a little bit of the aluminum off of the motor mount bracket to get it to clear.
I hope that the rest of the build moves a lot smoother than this, because it was frustrating that every day i went to work on the car, something else didn't work. And unfortunately the car is about 1 hr away from where I live currently, so it was extra frustrating because of this. Anyway, the pics of the goods:
My $20 stud :( (min order from SOR offroad M12->M10 stepdown stud)
Custom nuts that I drilled and tapped to clear the manifold:
Water neck was ground down to clear the T6 compressor cover and repainted. I replaced the top stock hardware with an appropriate cap screw. You can also see the BALLIN $20 stud.. (closest to the water neck on the bottom row):
Prepped and ready to go on:
Final result... the manifold is on for the last time!
On call 24/7
You are welcome sir!!! Good luck on the build!
