1 - 3 of 3 Posts
A bit of background to my issue: I killed my 7mgte last summer and ripped it out of my 89 supra turbo, planning on a bit of an oddball swap. Dummy me decided I definitely wouldnt rebuild it and put it back into the chassis, but now Im considering it. Problem is that I kept up with absolutely none of the sensors and need to know what the minimum sensors are that I need to run the engine with a standalone ecu on either a MAF or MAP tune as Im not decided on one or the other yet. Any info on what sensors I need to tune would be very appreciated!
Moderator
The sensors are usually included with the standalone. But intake air temp and MAP are the big ones, and your cam/crank/TPS sensors should already be on the car. Fuel pressure sensor might be needed depending on ECU.
1 - 3 of 3 Posts
