Status
Not open for further replies.
1 - 14 of 14 Posts
Hey Curt!
Hope you're having a great holiday weekend! :)
Couple of questions for you for Tuesday...
1) I've seen that you've emailed folks some pics/diagrams of the front bumper cover and undercover assemblies so that they can pick out miscellaneous nuts/bolts/clips/retainers/etc to make an order... would please you send the diagrams to me? Email: [email protected]
2) What's the difference between these 2 part numbers: 74232-14120 & 74232-14121?
Thanks!
Nate
Discussion Starter · #2 ·
I'll also be adding these (prices please?):
tailgate "toyota"grey-#75441-14190
tailgate "logo" grey-#75471-14010
tailgate "supra" grey-#75442-14280 [93.5-96 TT all NA]
to whatever miscellaneous hardware I end up picking out.
Thanks!
Thanks!
75314-14010 frt bumper cover emblem list 20.15 cost 14.90
75471-14010 rear center hatch emblem list 17.12 cost 12.66
75443-14180 "supra turbo" hatch emblem list 17.83 cost 13.19
75441-14190 "toyota" hatch emblem list 11.86 cost 8.77
Got 'em, Curt! Thx!
These diagrams are for all MkIV years, correct? My reason for asking is that in scan0001.pdf, part 52525 shows as one part using 6 pins. My car has 2 parts, with a small gap between and 3 pins each.
Prices and availability on these, please (all from scan0002.pdf):
90119-06355
90179-06242
90159-50311
90159-50316
90119-06354
90179-05060
53879D
51442
51441
And a couple of ?s:
1) 90159-50311 and 90159-50316 are similar except for length, with 90159-50316 being longer, correct?
2) Is 90179-05060 a "speed clip" w/attached nut? Round or rectangular/square? It's hard to tell from the pdf. Mine now are not round.
Thanks for your patience... it's a bit of a hodge-podge under my car.
Cheers!
Nate
Mk4ForMe said:
Got 'em, Curt! Thx!
CORRECT 93.5-98 PARTS DIAGRAMS, 52525 IS 2 PEICES WITH 6 CLIPS.
90119-06355 LIST 1.00 COST .74
90179-06242 LIST .63 COST .47
90159-50311 LIST .49 COST .36
90159-50316 LIST .49 COST .36
90119-06354 LIST .80 COST .59
90179-05060 LIST .69 COST .50
53879-17020 LIST 2.26 COST 1.67
51442-14040 LIST 141.15 COST 104.38
51441-14140 LIST 162.73 COST 120.33
Mk4ForMe said:
And a couple of ?s:
90159-50316 IS LONGER. 90179-05060 IS A BLACK SPEED NUT CLIP
Cheers!
Nate
CORRECTED
Okey dokey, Curt, here we go...
x10 --- 90119-06355 LIST 1.00 COST .74
x10 --- 90179-06242 LIST .63 COST .47
x20 --- 90159-50311 LIST .49 COST .36
x10 --- 90159-50316 LIST .49 COST .36
x10 --- 90119-06354 LIST .80 COST .59
x10 --- 90179-05060 LIST .69 COST .50
x5 --- 53879-17020 LIST 2.26 COST 1.67
x1 --- 75471-14010 rear center hatch emblem list 17.12 cost 12.66
x1 --- 75441-14190 "toyota" hatch emblem list 11.86 cost 8.77
x1 --- 75442-14280 (the "non" turbo one)
Also...
Price on the brass(?) machine screws that attach the rear targa hold-downs in the hatch space. And... price and quantity of the machine screws that attach the front hold-downs.
And finally...
Price on the gasket between the throttle body and the upper air intake plenum. FSM says to change it when TB is removed to change plugs. Is this absolutely required?
Thanks,
Nate
90159-60319 Screw, Rear List 0.75 Cost .55 Ea X 4
90168-45002 Screw, Front List 0.52 Cost 0.38 Ea X 4
17849-46020 Gasket, List 6.20 Cost 4.59
OK Curt,
Here's the full list of what I need this go around:
x8 --- 90159-60319 Screw, Rear List 0.75 Cost .55
x4 --- 90168-45002 Screw, Front List 0.52 Cost 0.38
x1 --- 63685-14020-C0 GARNISH, list 19.55 cost 14.45
x1 --- 63686-14020-C0 GARNISH, list 19.55 cost 14.45
x1 --- 17849-46020 Gasket, List 6.20 Cost 4.59
x1 --- 75442-14280 "supra" hatch emblem list ??? cost ??? (the "non" turbo one)
Is anything here special order?
Please use same shipping address and the "11001" credit card.
Thanks,
Nate
Discussion Starter · #11 ·
OK... remove the garnish pieces for now and please send everything else.
Tracking # also when you have it, please.
Thanks,
Nate
1 - 14 of 14 Posts
Status
