1 - 2 of 2 Posts
Vancouver
1993 jdm 6sp tt 173xxx km
I have a misfire on my 5th cylinder.i've tried almost everything regarding swapping parts.
I've swapped coils and plugs with other cylinders.
Repaired the connectors
Tried a new igniter
Engine compression was done and was fine
injectors were fine
Shops have recommended it being an wiring issue which led me to think it was either the igniter which i tried or the computer.
How can i go about the issue from this point other than taking it rg racing which have given me advice since the problem arose.
Trace the wiring up as far as you can go. I had the same thing and it ended up being some old wire was crispy/disintegrating.
1 - 2 of 2 Posts
