BACKSTORY: My engine head was recently rebuilt by a Mechanic/Machine shop who did all of the work. The block wasn't touched but was inspected for flatness. The head was put in an oven and then sandblasted to clean off everything. The day my car started acting up I had installed a boost gauge, wideband, AFR gauge, and intake pipe.
SITUATION FACT: My 1990 supra 7mgte has bad misfires at idle and at almost any rev range. Looking into my engine there are pools of fresh radiator fluid (coolant) covering the top of the spark plugs in the valley between the 2 valve/cam covers causing misfires and rough driving.
FIXES: 12th DEC→24th DEC- Removed and cleaned all the spark plugs. Cleaned the spark plug well of coolant and replaced the rear coolant heater hose because of possible pinhole. Ran fine for a while and then started misfiring again. Opened up to find it refilled with coolant.
I Believe these are the spark plugs in order. #4 is the cylinder with the most coolant in it and the spark plug looks like it isn't burning the fuel.
PROBABLE CAUSES: Reading around the net I saw some threads that said it could be the valve covers (doesn't make sense since it is clean coolant and not oil). Others said it could be the throttle body leaking coolant, but since there isn't coolant on top of the "No. 3 Cylinder Head" gasket/cover (there was some on the bottom of it) I think it has to be coming from inside the spark plug valley/well and not from a hose above the valve covers. I'm thinking it has to be the "freeze plugs" in the spark plug wells. I'm guessing they are leaking because of the heat treatment and sandblasting that the head recently got. I also asked the machinist who worked my head and he said the "freeze plugs" aren't likely the cause. Then I asked about if it was a crack from the work and he also said no, and that it would more likely be the plugs instead of a crack.
PLANS: I think I'm going to order the plugs from toyota (heard aftermarket is a shit show for these) and replace them and/or bring it back to the mechanic that did the work (But they don't open till 2-JAN-2019 because of the holidays and I might not feel like waiting)
NOTE: I don't drive my car that much. I drove it twice in the 13DEC→24DEC time period for a few hours each with about 6→12 engine cycles between the 2 events. On the 2nd drive (towards the end) is when I noticed the stutter.
VIDEO:
RESEARCHED THREADS:
https://www.supraforums.com/forum/s...s.com/forum/showthread.php?664950-Oil-Water-In-Your-Spark-Plug-Galleys-Write-Up
http://www.toymods.org.au/forums/threads/67381-How-to-remove-water-gallery-plug-7mgte-head
http://www.toyota-supra.info/forums/mkiii-supra/16449-coolant-on-top-of-spark-plugs.html
https://www.supraforums.com/forum/showthread.php?244785-Fluid-in-spark-plug-galley
http://www.mkiiisupra.net/bbs/7m-technical-section/40539-weird-issue-help.html
VIDEO:
RESEARCHED THREADS:
