1 - 10 of 10 Posts
Respect
Is it common for mkivs to miss with plugs gapped at .028-.030? I just put in some ngk 6097's at my car is missing past 4k.
488ci V10 Power
For a single car, i have mine gapped at .025 and i know others keep it there as well.
is the car single? stock twins?
Respect
Twins, the car runs great till any boost starts flowing and thats at around 4k. It hits 12psi easy so i know its not a boost leak because i just checked everything. As soon as i hit it and the revs get to around 4k it misses like a mofo.
488ci V10 Power
for stock twins i always get the gap between .030 and .032. whichever works best. You might be gapped too far down.
You have a BCC right? You'll hit boost cut from the ECU at about 14psi and above.
Supra TT Senior
Jarrett I JUST put in NGK 6097s at their stock gap (.032) and the car has run fine...then again I havent even really boosted her yet but I'll let you know tonight. Like MK4 said, you just might be gapped too far down.
Respect
Discussion Starter #6
Yes I have a bcc and have never had a problem b4. It doesn't even like to rev past 4k~. It missing and stumbles and as soon as boost starts to build it gets worse. I'll try less gap and more and see what happens. For some reason im thinking i need new coils. But when it misses it does feel like boost cut but its more random. It stumbles to build rpms when im at a stop in neutral.
488ci V10 Power
Gap the plugs up to .032 and go from there. Shouldnt take more then 20 mins to change them all :)
Respect
Discussion Starter #8
It doesn't. Just a pita because i've been workin on the car for almost a week. Thanks for the help Mike, and Jack.
Supra TT Senior
I know how you feel. I felt that way when I spent 4 hours trying to change a new radiator! :eek:
Let us know if it fixes it Jarett
Respect
Discussion Starter #10
Didn't fix it. Its breakn up like a mofo. I'm going to take it by a place tomorrow so they can run all the codes. It feels great till boost hits, so i guess i'll update when i know.
1 - 10 of 10 Posts
