I was wondering if it's possible to put a 6speed trans from a mkIV in a mkII to gain better highway economy. Will it fit? Are the ratios different enough to wrrant such a swap? Where can I get a trans?
i dont think there is a bellhousing that will mate from a mk4 6spd
to a m series engine.. not 100% on that though, it would not be easy or cheap and probably not worth the effort if you can do it at all (tranny is probably worth 1000+) if you want to swap out
your w58 i would suggest a r154 as they are stronger easier to fit and alot cheaper
hth
Scott A
You will not get better highway economy with a Getrag V161 6-speed; only 6th gear is overdriven, and the ratio is not much different to 5th gear on a W58.
V161's don't have separate bellhousings like W58's, so adapting one to an M series engine (or anything apart from a JZ engine) would be very difficult and costly.
No One Ever Listens To Me
very true on all accounts....guy who knows trannies! :D
also i odnt see how the enlongated gearing of the getrag would be well suited for the normal gearing of the mk2.....
for examples top speeds in both cars are drastically different.....
...which brings us full circle. if you want better highway economy, swap out your final drive. go for that 3.71..numericaly smaller=longer gear=faster top speed=more economy at lower speeds. but then you can kiss your torque down low byebye.
