1 - 2 of 2 Posts
Hi, my car is a mk3 with 1jzgte head and 2jzgte block. Je pistons, eagle rods, custom intake manifold,90 mm throtle. Stock head and cams. Stainless steel manifold. Precision 74gts turbo, 3inch exhaust. Devils own water methanol kit with 250 psi pump set at 200 psi. Im looking for 700 to 750whp. (motor is 3.0l 26 to 30 psi 7500 to 8000rpm. 93 oct pump gas with methanol kit. What is the recomended nozzle size for this set up. Im using (M) nozzles. Run 100% methanol. Im looking for 3 nozzle set up, before throtle body.
The "Tactileneck"
If you're running multiple nozzles you can run smaller nozzles for better atomization. 3 is alot in my opinion. 3 X M6 should be plenty. 2 X M8 should be more than enough also, just cap the 3rd. You could probably even run one M10 and get away with it if you're on 93. Feel free to call Chance directly and chat with him, he's very helpful.
Good luck.
1 - 2 of 2 Posts
