1 - 19 of 19 Posts
Supras are never 'done'
1989 Toyota Supra
All parts will be shipped from Bozeman, MT 59715.
PRICES DO NOT INCLUDE SHIPPING.
Reasonable offers considered.
PM me with your ZIP code for shipping quotes.
I also have an E153 Turbo Auto transmission that was recently rebuilt but is starting to shift slowly again. $50 to pick up (yeah right, like any of you live near here :)) or $100 plus shipping for my effort to crate and ship. This was a $2000 rebuild by the previous owner in late 2002, or around 5K miles ago because the car hasn't been driven much. If you know your automatics, this one's for you.
$50 -- 7M A/C pump with 1JZ head (just to keep it clean):
$20 -- Stock airbox w/ K&N that needs cleaned:
$10 -- 3rd horn that mounds above the brake booster for the alarm:
$20 -- A/T transmission mount:
$20 -- Stock BOV:
$35 -- Clutch fan: SOLD
$20 -- New N/A stainless clutch line (ordered N/A on accident):
$30 -- Turbo ECT ECU:
$10 -- Turbo auto fan relays:
$10 -- Fuel pump relay and resistor:
$10 -- Front driver's side grille, with TOYOTA badge, missing replacable clip:
1989 Toyota Supra
Discussion Starter #2 (Edited)
$15 -- Stock heat shield:
$5 / ea -- Misc hoses, IAC / breather / fuel return / brake booster / 1JZ heater:
$40 -- Stock IC in great shape, with brackets:
$15 -- Oil cooler, with lines and bracket:
$30 -- PS pump w/ bracket: SOLD
$15 -- PS reservoir:
1989 Toyota Supra
Discussion Starter #3 (Edited)
$20 -- Turbo auto radiator and cap, needs new drain plug rubber o-ring:
$20 -- Auto shifter:
$20 -- Lower fan shroud piece:
$2.50 / ea -- 2.75" x 3 and 3.25" x 2 Clampco t-bolts: SOLD
$25 -- Turbo torque converter, stock replacement with very low miles:
$20 -- Flexplate and bolts:
$15 / ea -- Front TEMS motors:
1989 Toyota Supra
Bump...
1989 Toyota Supra
87_7MGTE said:
thats not a heater vsv, its either for egr or the fuel pressure regulator
No, it's a heater VSV. Check your facts before you state them as such.
It came with my 1JZ. When they pulled the motor they unbolted the heater coolant valve from the firewall instead of removing the hose, so it was still attached. It was RHD though so it wouldn't fit a LHD but the VSV is the same. I haven't tested it but I will if someone wants it. Spinningheadboy, do you need a valve? I can test it this weekend and let you know if so.
1989 Toyota Supra
Discussion Starter #10
foofers said:
Dibs on the power steering pump....it doesn't leak?
Is that for the 7mgte or 1jz?
I overhauled the pump (new seals, checked specs) recently before I swapped in the 1JZ. I did this because I thought it was leaking, but it was actually the reservoir to pump hose. The pump is for the 7M.
PMs sent regarding shipping.
1989 Toyota Supra
Discussion Starter #12
PS pump sold.
1989 Toyota Supra
Discussion Starter #16
David_Nguyen said:
paypal locked and loaded for vsv and shipping to bc canada
VSV was shot, sorry.
garage, sorry no gray door panels man, just brown :p
1989 Toyota Supra
Discussion Starter #17
Clutch fan sold
1989 Toyota Supra
Discussion Starter #19
Bump... make me some reasonable offers... let's move some parts :)
1 - 19 of 19 Posts
