1 - 4 of 4 Posts
Damn that was close. I didn't know those Camaros are making 580 crank hp out of the box.
boost'en down 101
Interesting to see, I'm likely sitting around 500 and barely inched out a stock auto ZL1 the other day..
What's the spec on that s363?
I have s300FMW(61.5mm), divided, .91
its the older cast wheel version. i put a .83 divided housing on it to help spool besides that nothing special. that was racing hitting like 19ish psi peak then settling down to 18ish psi towards redline. pretty sure he said his car weighs around 4500lbs with him in it and he had a passanger too. has a big aftermarket stereo and all. he starts to pull away when i hit 5th his 4th gear goes to 158mph. his gearing is way better for high speed runs. im guessing im right around 500whp on pump gas. that guy must have not been stock or your car isn't making that idk.
yeah theyre no slouches he dynod 570whp on pump gas.
1 - 4 of 4 Posts
