Well, I'm in Texas...
I have an 83 P-type 5 spd with some problems that I am about to part with....
It has only 127K miles. It leaks oil in several places, the newest being the rear main seal. It runs fine as long as there is oil added frequently. Here are the other problems...
Dinged up right front fender
Minor body damage on right side
Sunroof motor good, but the track (the wire thing) is gone
Needs new parking brake lever
Left door lock has fell into the door panel
Sun oxidized paint
Rust on hatch and typical MKII places
Needs one rubber exhaust hanger
Valve stem seals need replaced
No A/C
Here is the good...
Interior is decent. Driver seat has a little wear and tear on the plastic parts.
New water pump.
Timing belt installed new at 110K.
Tranny only has 65K miles.
New clutch at 110K.
Two very good tires (Michelin, 8K mi), and two good tires (Falken 16K)
Aftermarket exhaust. Only a little better than stock.
Gutted cat.
I don't know if your interested, but make an offer if you are. I'll be letting this go cheap.
