1 - 4 of 4 Posts
2JZ NA-T
I had a question about the MKIV and MKIII wheels...im pretty sure they are the same exact patern b/c i see MKIII guys rolling with mkiv wheels all the time.... but will the MKIII spare clearn the TT brakes? or even the NA ones?
thanks
I used to have a 90 tubro with MKIV NA wheels. The back will fix great. But the front will rub the inside of the rim when you lock turns. But there is a screw where you can adjust so that when you turn the wheels it will stop at the screw and not the whell. Or you can always get spacers.
Finally up and running!
IIRC, the MKIV's used in rally had sawblades on them, so it might work. Looking for cheap wheels to put drag radials on?
Dr. Jeff Lange
Sawblades will likely fit with N/A brakes, however they are only 16" and will not clear the TT brakes.
Jeff
1 - 4 of 4 Posts
