1 - 20 of 167 Posts
Discussion Starter #1 (Edited by Moderator)
Ok, so since the OP of the previous thread like this has been non-existent for a few years, we're going to start this over and keep it updated. Post a video and/or timeslip, engine, and mods. MODS PLEASE STICKY!
2jz
1. [email protected] jamesmkiii- 1991 Hardtop Built 3.0, 2JZ-GTE, Crower 272's, Precision 7680 Billet, TH400, PRO EFI 128 Flex Fuel,FIC 2150cc, LQ9 Coil's. 8.8 Cobra IRS, Direct Port Nitrous. 3390 Race Weight
2. 8.701 @ 158.39 MADSUPRA88- 2JZ, Precision 7675, FTI TH400, FID 2000cc inj, GSC S2, E85, 45psi, 1.313 60'
3. [email protected] BIG DADDY- 2JZ
4. [email protected] joliroger4- 1.357 60', Stock 2JZ Aristo Longblock/Cams, Precision 6766, GSC S2s, TH350, Haltech PS2000, Twin MSD DIS-4s, MT Drag Radials - Street Driven
5. [email protected] CPUELLO- 2JZ Power Glide
6. [email protected] 2jzmk3- Precision 82mm turbo, MoTec M800, Pro Analysis, M&W Pro16, Motec SDL3, GPS, SLM, And MoTec's Video Capture System
7. [email protected] JawsGear 92 Supra 2JZ TH400
8. [email protected] SuperRunner & Tun_x- 1989 Supra - 2JZGTE, old cast wheel comp 76mm, powerglide, AEM V1, E85, boost only
9. 9:[email protected] Stanley Suffrant 2JZ Powered 6spd MKIII+NOS
10. [email protected] TurboStreetCar 2JZ MK3, Bc272, 6466, ProEFI128, Th350, 275/50/15 1.538 60'.
11. [email protected] 135.46 Newgen- BW S366-66 Spool Valve Drew Go Manifold Godspeed Intake Manifold AEM V2 Weldon FP, percision 1200cc injectors, Maxx Autowerk IC, TH350, 4000rpm TCI stall, 3.5 inch drive shaft, GSC S2 Cams/Springs, and e70
12. [email protected] Black89t- na-t,tt hg/arps, ffim, s363, mvr44, os giken twin, 7m ecu!!!, 20psi, 255/50/16 mt drag radial, 3500lbs
13. [email protected] 2jz88mk3- T67 p-trim 0.81 at 26 psi on 94 with around 600cc of 50/50 water/meth, BC 264/Springs/Rets, stock short block, PS2000, 275/40/17 Nitto NT01's at 32 lbs cold pressure (regular street), anti-lag/2step turned off, 3810 lbs with me, r-154/3.91.
14. [email protected] jamham1988- Precision 6262, microtech standalone, fmic with 2.5in piping, 3in exhaust, et streets
15. [email protected] Nick Stonawski- 2jz, t88, 552RWHP @ 16psi rock hard 5 year old street tires
16.
1.5jz
1. [email protected] T4-TEG- full weight street car, AEM V2, 9:0 cp/manley bottom end, stock head, 272 cams, th400 with trans brake, 80mm turbo, E85, 837 whp. ET street tires, and a 100shot for spool only
2. [email protected] nestor cotto - TH400, 5000 rpm stall, 272BC cams, manley rods, JE pistons, 3434 lbs, BW 75mm turbo, q16 vp, microtech ecu
3. [email protected] John shannon 1.5 jzgte with a th400 trans
4. [email protected] SUPER SUPRA- Precision 6766 272 cams E85 Haltech Sport 2000 1200cc RC injectors. 305 drag radials.
5.
6.
7.
8.
9.
10.
11.
12.
13.
14.
15.
1jz
1. 9:[email protected] Gardiel Garcia Hi-Per Racing maeso 1JZ 5spd and MicroTec standalone (Who'da thunk it could happen!) 3100lbs with driver
2. 11:[email protected] MattOneDime 1JZ 5SPD
3. 11:[email protected] jwcatto 1JZ powered 5spd HKS T51
4. 12:[email protected] Hank2 harwewe1 1JZ 5spd.
5. [email protected] JZA70 QC- stock twins at 17 psi, stock injectors, 264 hks bump sticks, 12x24x4 fmic, y pipe downpipe with 3" exhaust system, fully built stage 3 turbo 400 tranny with transbreak, 1 piece aluminum DS, 26/11.5r15 (275/50r16) mt et street drag tiers, 4:10 torsen diff.
6. [email protected] AGlobalThreat- 380 rwhp, 2500 lbs, 5 speed, 4 x 245 NT01s, Driftmotion 1jz CT26[/b]
7. [email protected] C2M 1JZ powered 5spd
8. 13:[email protected] Turbo Drifter 1JZ powered 5spd stock turbos
9. [email protected] Scupra- 1jz, universal intercooler, 3" turbo back exhuast, pod filter and a bov
10. [email protected] jza71 1JZ powered 5spd stock turbos
11.
12.
13.
14.
15.
7m
1. 9:[email protected] km/1:38 60 ft. supraslakt
2. [email protected] 139 TKMK3- gm 350 Trans, 4400 stall , pro efi 48 , precision 7168, front facing intake mani made by me , 272 cams, stock valves and ports, 15x9 Hoosier slick. Weighs 3700 w/me in it.
3. 10:[email protected] Ivfinalstage28psi & 75 shot
4. 10:[email protected] James Daley 771hp and 731tq 5Spd No NOS!
5. [email protected] 1.79 60' Slow66 {Freakin flying!}
6. 10:[email protected]:08 giomally sille MK II 5M GTE CT26 & 75 shot @ 2525lbs and a 1:49 60 ft.
7. [email protected] SideWinderGX - 1.79 60', 7M on E85, Precision 6062 gen2, rebuilt A340E, 3000 stall, ProEFI, supporting mods
8. 10:[email protected] Lance Wolkens 90 T with GM tranny no NOS
9. [email protected] maeso
10. [email protected] upgradedsupra
11. [email protected] outofstep
12. 11.366 @ 130 Toyotanos- 67mm 7M, E-85
13. 11:[email protected] stevevangst
14. [email protected] supraslakt
15. [email protected] VanSupra
16. [email protected] yota8791- 7m, greddy 20g, apexi neo
17. [email protected] Toyman1987
18. [email protected] wilsonsupra
19. [email protected] MRSUPRA HPF/SP59GT 511rwhp Stock 7M
20. [email protected] MKIIISupraGuy
21. [email protected] Mike 92LX
22. [email protected] drjonez
23. 12.2 @ 122.XX MelloYello
24. [email protected] 112 supranasty- CT26 and Nitto DR
25. [email protected] SupraTrey
26. [email protected] Frontierguy2 7M bolton 58mm, pump gas, 19 psi, 660 injectors
27. [email protected] supra87 t3/t4
28. [email protected] NealMulcahy
29. [email protected] BTZ
Any other motor
1. 12.04 @ 111.77 lowtaco- 355 sbc Dart Heads, Powerglide with PTC 3800 stall, 3.91 gear, Foot brake on two step
2.
3.
4.
5.
6.
7.
8.
9.
10
Captain Slow.
if your gonna make a list. make them separate like they should be..
Captain Slow.
as in putting the M series together and the jz series together.. Make separate lists
Addict
i'll get some drag strip times in a couple of months lol.. full weight mk3s just aren't the best "FAST" car unless you got tons of money, or determination/time :) or put a nice 7m in a mk2 :)
I already put you on the list bud lol.
Yes I realized that but I wanted the time slip and video in the thread. I'm working on getting the 8 second one. Rather be at the top of the list.
1 - 20 of 167 Posts
