Went down to the dyno today and got sad results. I'm running stock 440’s with MAFT and when we tune to safe A/F levels (11.4 to 11.8), I'm hitting fuel cut at 9 psi...?! When we try to tune out the fuel cut we're getting scary numbers like 13.5 AFR @ 4500 rpm!! We even tried lowering the injector size to 420cc (BASE = 0) and still fuel cuts like crazy... For the heck of it even tried limiting the Hz: Normal, 1500, 1450, 1400... Nope, just nothing works.
Once we even hit fuel cut at 1200 Hz!? What the hell?! I heard that once our cars switch to open loop we should be seeing some really rich numbers like in the 9's and 10's but I'm nowhere near those numbers.
What can it be? What do you think is wrong? My base settings are: AUX = 0, BASE = 2, IDLE = 0, MID = 1, WOT = 2. And my fine tune settings are: 3000 = 3, 4000 = 3, 5500 = 0, 6500 = 0. I didn't even get to tune the 5500 and 6500 rpm range because I keep hitting fuel cut before 4500 rpm, very sad... I heard that with the MAFT people are able to run 14.5 psi comfortably with stock fuel system because once on WOT, our cars run so rich that people need to SUBTRACT a lot fuel. Well, I'm nowhere close... I'm having to ADD fuel 'cuz it's so lean and once I do, I'm hitting fuel cut at something stupid like 9 to 10 psi, lol. Geez, this is frustrating, please help. Thanks,
For reference my mods are: Upgraded IC and hard pipes, ball & spring type MBC set to 14 psi, full 3" turbo-back exhaust, MHG, SSQV BOV, MAFT & S-AFC II (not being used, will use to fine tune after MAFT is properly set).
p.s. I haven’t changed the fuel pump but I’ve changed the filter 2 years ago. Other than that, my fuel system is totally OEM. Thanks,
Jason L.
Jason L.
