Is there anyone out there who has an automatic transmission they are parting out? I need an
ABS Wheel Speed Sensor
8954414030​
I have an 87 non turbo. The part number is the same throughout the MKIII series. Thanks!
No problem
Part # 89544-14030​
I did a verification with a Toyota rep and found the part I need was only used in the Supra's built between August 1986 and August 1988. The part number was unchanged for the entirety of the MKIII line. So the mission continues.
Part # 89544-14030​
If this 'rear' abs sensor is the one located on the a340 trans, i can almost guarantee it is identical to cressida a340 abs speend sensors. They should be cheap as chips and readily available. Why not just buy one and see if it works? I can't imagine anyone wanting more than $5 for it since a whole gearbox is usually free - $20.
