I was wondering if anyone knows anything about the feesibility of putting a mkIV 6 speed trans in a mkII for better highway economy. Will it fit? Are the ratios different enough to warrant a transplant of this kind?
This swap is in the category of: "If you want to spend a few grand to gain 3mpg be my guest".
You're asking for a world of pain and expense if you even attempt it...good luck.
Dr. Jeff Lange
Unless you can find a rear end for your MKII in the 3.2 - 3.3 to 1 range, you'll lose fuel economy, as well as top-end speed.
6th gear in the V160 is nearly the same ratio as 5th gear in the W58. In other words, it will make zero difference to highway fuel economy.
The V160 does not have a separate bellhousing like a W58, so adapting it to an M series engine (or anything apart from a JZ engine) will be a world of pain. In short, forget it.
