1 - 3 of 3 Posts
T
Does anyone know if there is aftermarket front brake calipers available for a 94 N/A supra, and who makes them?
What You Know About That
You should check out the NA section. As long as the rims are big enough, you can fit any TT calipers on an NA, whether they be Brembo or stock.
Swing on deezz!!!
Yea...I upgraded my NA to TT brakes in the front...HUGE improvement. They bolted on, but the backing plates have to be removed for the larger TT rotor. Side note: Upgrade to stainless steel brake lines...pedal feel and effort are dramatically improved over the stock rubber. Mine looked like this when installed
Stock calipers, TRD rotors, Russell lines, EBC green pads= windshield modifications with forehead if you're not careful :lol:
Mark
1 - 3 of 3 Posts
