Status
Not open for further replies.
1 - 12 of 12 Posts
Hi Curt,
I would like to have some maintenance parts for my `94TT 2JZ GTE:
-Necessary amount of Toyota FIPG for sealing engine lower oilpan
-Trd engine mounts & Trd tranny mount
-Upper heater hoses (These, I believe: 87245-1b330 Hose, 87245-1b320 Hose). I Don`t need the heater hose which comes from the back of the cylinder head ( I believe it is this: 87209-14840 Hose), as I have already changed it.
+90467-22011, Clip X 4
-Water hoses & clips:
16261-46040
90467-13050 X 8
16264-46030
16267-46011
16281-46020
16282-46010
90467-22003 X 2
16283-46030
90467-20005 X 4
16286-46010
90467-15016 X 4
16287-46010
16295-46040
-Vacuum hoses & clips:
90445-10073 Hose no.1
90467-10106 Clip, no.2 X 4
96135-41100 Clip X 10
17345-46020 Hose air no.5
17346-46010 Hose air no.6
17347-46010 Hose air no.7 X 3
17348-46010 Hose air no.8 X 2
23827-46010 X 2
23829-46060
23829-46070
90445-08289
90445-08298 X 3
90445-08313
90445-12256
90445-12263 X 3
90447-08091 X 2
90447-08099
90467-07094 X 4
90467-12062 X 11
95333-06020
95333-06030
96132-41100 X 4
90999-92002 Std. Hose X 3
+6spd swap parts:
Clutch parts:
90363-12002-77 Bearing, pilot
96152-00500 Ring, snap
90903-63001 Bearing, release
90560-50001 Spacer
90560-79001 Spacer
90206-12006 Washer
90520-75001 Ring
31264-14060 Spring
31234-14020 Spring
90119-08079 Bolt, cover X 6
31234-14020 Spring
90910-02115 Bolt Flywheel X 8
13450-0W011 Flywheel
Transmission:
08885-01306 v160oil qt X 2
+ 90311-90006 engine rear main oil seal
Clutch hydraulics:
31470-14060 slave cylinder
90080-10055 bolt x 2
31410-14310 master cylinder
90179-08237 nut x 2
31481-14260 tube
96816-50335 hose
31484-24010 bracket
31484-14090 bracket
31482-14060 tube
90119-06406 bolt
96991-10080 clip x 2
90119-06733 bolt
90080-11231 bolt
90461-08702 clamp list 2.61 cost 1.99
Shifter assembly:
33504-14130 shift knob
33530-14442 93.5-95 short throw shifter
Console parts:
58261-14010 upper trans tunnel list
58994-14010 console bracket
91651-60614 bolt x 2
Brake pedal:
47101-14230 brake pedal
31321-14020 brake pedal pad
78119-24020 gas pedal stopper
Clutch pedal:
31311-14120 clutch pedal
90541-06036 cushion x 2
90949-03011 spring
90386-13015 bushing x 3
90949-03013 spring
31321-14020 pedal
90101-10015 bolt
90387-10003 collar
31353-14010 holder
90240-08006 pin
90386-08010 bushing
55107-14140 support assy
91655-60630 bolt list
90119-08a22 bolt list
90082-61005 e ring
94512-01000 washer
94110-51000 nut list
90386-05017 bushing
90206-08001 washer
90468-16142 clip
88280-14030 switch list
94120-41000 nut
That`s it, I think! And shipping to 94100 FI (Finland).
Thank you!
Best regards,
Mika
Hi Curt,
E-mail received!
I will make little changes to the parts I listed above so the corrected list will be coming soon!
Thanks!
Regards,
Mika
Hi Curt,
Can you qive me a new price quote to the list I corrected of the first post?
Thank you!
Best regards,
Mika
1 - 12 of 12 Posts
Status
