Status
Not open for further replies.
1 - 20 of 40 Posts
41110-14780 COMPLETE DIFF ASSY LSD TORSEN 6SPEED 3.13 GEARS LIST 3982.52 COST 2750.00
41301-14080 INTERNAL TORSEN DIFF UNIT[CARRIER] STOCK LIST 3673.74 COST 2695.00
[YES IT IS CHEAPER TO BUY THE COMPLETE ASSY LISTED ABOVE]
PTR04-00025 TRD LSD INTERNAL UNIT[CARRIER]. LIST 1025.00 COST 854.00
41201-80055 3.27 JDM GEAR SET [ RING/PINION] LIST 1246.00 COST 935.00
[ includes ring gear/ pinion gear/ nut / bolts/ crush sleeve/ pinion seal]
41201-80058 3.13 USA GEAR SET [RING/PINION] LIST 1239.00 COST 905.00
http://www.supra-forum.com/articles/general/differentials/
REBUILD PARTS:
41181-14080 aluminun diff cover list 348.24 cost 261.18
90179-28006 pinion nut list 4.14 cost 3.10
90311-50018 pinion seal list 30.00 cost 22.50
90366-38009 pinion bearing list 74.19 cost 55.64
90366-50039 pinion bearing list 118.66 cost 88.99
41231-14110 crush sleeve list 13.36 cost 10.02
90366-54014 side carrier bearings list 73.44 cost 55.08 ea x 2
96721-31110 side carrier cover o rings list 5.69 cost 4.27 ea x 2
90311-45013 axle seals list 36.83 cost 27.62 ea x 2
00295-01281 FIPG sealer list 22.98 cost 17.23
1994 Toyota Supra Turbo 6spd
curt- dumb post from me here, but if we get the 3.27 ring gear/pinion set, we don't need all of those small misc "REBUILD PARTS?" all we need is the DIFF (TRD OR TORSEN) and the 3.27 and put it back in the pumpkin?
You'll need all of it.
41301-JA800 TRD LSD INTERNAL UNIT[CARRIER]. LIST 970.20 COST 852.59
41201-80055 3.27 JDM GEAR SET [ RING/PINION] LIST 595.84 COST 440.61
90311-50018 pinion seal list 20.89 cost 15.45
90366-38009 pinion bearing list 62.73 cost 46.38
90366-50039 pinion bearing list 100.20 cost 74.10
90366-54014 side carrier bearings list 49.50 cost 36.60 ea x 2
96721-31110 side carrier cover o rings list 3.74 cost 2.77 ea x 2
90311-45013 axle seals list 25.86 cost 19.13 ea x 2
00295-00103 FIPG sealer list 12.78 cost 9.36
Senior Member
41110-14780 COMPLETE DIFF ASSY LSD TORSEN 6SPEED 3.13 GEARS LIST 2563.80 COST 1967.34
41301-14080 INTERNAL TORSEN DIFF UNIT[CARRIER] STOCK LIST 2938.81 COST 2173.16
so, the diff alone is more expensive than the entire diff assembly(pumpkin)? Ive seen a lower price for the assembly, whats the current price?
[3.27 GEAR SET DISCONTINUED AS OF 1/1/07 THEIR ARE NO MORE LEFT]
41201-80058 3.13 USA GEAR SET [RING/PINION] LIST 865.93 COST 650.74
Somebody's Watching Me!
hey curt would the ring and pinion out of a gs with the 3.26 gearing work in a 6 speed pumpkin since the 3.27 gearing is sold out? thanks david
Senior Member
I have read on this forum that someone had swapped the 98 gs400 3.26 non-posi diff for a trd diff and it drops in. I also read you can use the mkiv auto tt lsd diff with the lexus pumpkin.
However, the gears from an auto into a 6 speed pumpkin is not possible.
Nope, the diameter is smaller than the 6 speed.
Can you confirm that the mkiv auto tt lsd will fit a 98 gs400(w/ 3.26 gears) pumpkin?
If not, which LSD can I buy for the 98 gs400 pumpkin?
If possible, please list the part numbers.
Boost Addict
Curt... can the side gear shaft snap rings and ring gear set bolts be re-used when rebuilding the rear on these cars? I was looking at the TSRM and they state these parts as "non-reusable" but you dont list them with the rebuild parts?
1 - 20 of 40 Posts
Status
