1 - 20 of 108 Posts
· Banned
yesterday i drove the car to work 32miles, then drove it to the track 28 miles, then made 2 passes and drove it 55 miles back to my house. here the results:
33psi and spary
full weight
26" tall slicks
1st pass
with small burn out
spinning thru 2nd
60' 1.47
330' 4.03
594' 5.70
1/8 [email protected] mph
then i turned the boost up
2nd pass
did a 1-2-3 gear burn out to the 60' mark hoping that would get it to hook, but the
car blow the tires off in 1st i was trying to drive it thru hit 2nd and it started spinning worse so i let out befor almost crossing the center line and almost hit the 330 timing light.
60' 1.65
330 4.2
1/8 [email protected] 71mph
time for some 28" tall tires and more boost and spary!!!
video
pass 1
http://s437.photobucket.com/albums/q...0606092251.flv
pass 2
http://s437.photobucket.com/albums/q...606092251a.flv
time slips
pass 1
http://s437.photobucket.com/albums/q...0606092246.jpg
pass 2
http://s437.photobucket.com/albums/q...0606092245.jpg
· Banned
Very nice mph! Hopefully the tranny keeps holding up for you! You probably need to go with a 15 inch tire at this point.
yah there 15" but i need to get some 28" tall tires for the.
I agree!! 15th inch tire for the win for more side wall with a 28 inch tire..
· Boost Junkie
Nice the 6.07 should be good for a 9.2 or 9.3. Why not take the car down to Beech Bend in Bowling Green? It is a 1/4 mile track. The 28 inch tall tire will be enough to get you to where you want to be as long as the trans doesn't break first.
Good job!
Steve
· Banned
· Banned
Discussion Starter · #10 ·
Do you have timeslips or video for these 2 runs?
Please put them up.
Sean
yes, let us test them for you so the haterade will goo away:rant2:
Not hating. And congrats on the 6.0. That's very quick for a built auto. But I still think his dyno numbers don't add up. I been saying that since the beginning. He should be running alot quicker than a 6.0 at 967hp. I ran [email protected] with onl 735hp and when my nissan had a 74mm it ran 8.6 (1/4) at only 750 up in a 3100lbs car with driver..
Congrats again!!!
· Banned
Discussion Starter · #19 ·
Congrats again!!!
this sounds like a BL story :nuts: .
1 - 20 of 108 Posts
