1 - 8 of 8 Posts
Hello everyone, this is my first forum post as I am very new to the car modding scene.
I am looking for help with building my 2003 Lexus is300. I want about 250-300hp with the possibility of increasing it in the future. Im curious to know what things I need to do to get to my horse power goal. My budget is around 2-3000 maybe more. Should I go for an NA-T build? Any and all information is much appropriated!!
Super Moderator
Unfortunately, 2JZ-GE IS300's are all-or-nothing. Basic intake/header/exhaust mods wake up some HP but won't make your HP goal by a long shot.
After that, the stock ECU is hot garbage when it comes to dealing with modifications, so there's no 'easy' or 'just a little more' or 'staged' upgrades.
Stage 1 is a complete turbo kit and a standalone ECU on a split harness to share the stock ECU with the rest of the car, after which it will never again pass an OBD-II scan or engine bay check for an emissions inspection or compliance inspection, and you'll be chasing CEL's and weirdness for a little time or a long time depending on what all you do.
If you roughly double your budget to $5-7k or so, you can piece together a decent quality turbo kit and a good engine management/ECU solution, along with the injectors and fuel pump upgrades required. Supporting mods like a clutch, catback exhaust, built trans, trans coolers, LSD differential, etc are all on top of this $5-6k requirement.
That'll get you to a safe 300-350whp on lower boost levels very easily. From there, getting into the engine is mandatory to install connecting rods that won't fail at 400hp, and also reduce static compression with a stock TT Supra headgasket to avoid detonation on pump gas with moderate boost levels. This inevitably turns into a 'while you're in there' snowball where aftermarket forged rods and pistons and cams and a nice front facing intake manifold and all kinds of shit shows up, and the engine's ready for 800-1000whp, or more if you do billet mains. This can be done for around $3-4k if you do it all just right and your block needs little if any machine work, but it snowballs into a $5-20k process very quickly with things like stroker cranks and billet mains and cams/headwork/billet intake manifold, etc
Then your stock transmission explodes suddenly and violently (W58 or A650E auto) and then you're onto a powertrain solution that'll play nice with the IS300 gearing, which means a $3-5k R154 5-spd setup w/decent twin disc clutch on the cheap(er) end, or a Grannas Magnum T56 conversion with a nice McLeod or Tilton clutch for 7-12k depending on options. Or a PHR 6R80 Ford auto trans swap which runs 5-8k depending on where you source the trans and whether or not you build it, and what kind of shifter setup and trans control you go with - some more expensive standalone ECU's can run this trans, otherwise you're in for a $1000+ trans controller. Gearing gets weird with available IS300 rear differentials as well, so things like a Getrag V160 or Nissan CD009 are poor candidates because you can't easily get a rear diff ratio that matches the trans gearing very well.... and the 6R80 is as well now that I think about it.
And then you realize that you're about $25-40k into this build (not including labor if you haven't done all the wrench-turning yourself) and you haven't touched the wheels, tires, or brakes to match all the horsepower.
Truly, if you really want a turbocharged IS300, I'd strongly recommend saving your money and buying one that's already built. You'll save at least $10-15k vs building the same car yourself.
Just in case you're wondering, 'All motor' isn't viable unless you'd like to spend the same $25k to make your 300hp goal. Another Supraforums member built a non-turbo 2JZ-GE Supra, and while the result is glorious it took a LOT of work to make ~270whp. ITB's, $$$$ Custom header, $$$$ Custom headwork and big cams, etc.
Sorry to be the bearer of bad news, I love those IS300's myself, but they're not an economical car to build at all.
Wow this is a lot of stuff to take in lol. But thank you. Looks like I have some decision making to do.
You are a legend for typing all this out for me. If you could put the mods I need to reach 300-400hp safely and reliably, I will love you forever.
Also what would be my best option to keep the car passing emissions so it can be street legal?
Super Moderator
You're welcome! Glad it was helpful. 🍺
The first two paragraphs cover it, really. You'll need a decent quality turbo kit, ideally with ~61mm or smaller turbo, along with a matching intercooler and exhaust setup.
A drop in fuel pump like a Walbro and a set of ~550-750cc injectors that fit the stock fuel rail, and a quality standalone ECU that is available with a PnP harness for an IS300 that retains the stock ECU to run all the Canbus stuff the IS300 needs like gauges. You'll also need the associated sensors, wideband O2, and a professional tune.
~350whp is about the safe limit for the stock VVTi 2JZ-GE block and rods, as well as the safe-ish limit for the stock auto trans or W58. Spend some money on a big trans cooler if you've got an automatic and get an upgraded clutch if you're on a W58. Enjoy the HP, but don't beat on it like a teenager with a new Mustang GT or you will break something.
Passing emissions will depend on where you are. Some states/cities let almost anything on the pavement, others freak out about a cold air intake. But if a visual inspection of emissions equipment or an OBD-II ECU scan are involved in your locale, a turbo kit will never pass.
Well I won’t have to worry about passing emissions with a turbo until I have the money to buy one. I live in Missouri but I've never registered a car before so I’ll hopefully there’s no strict rules. It’s being inspected by a shop that specializes in JDM/imports so I’m hoping they’re a bit less hard on testing for emissions. Again, thanks for the info you are a blessing.
1 - 8 of 8 Posts
