I tired of replacing my front lower control arms on my Supra. I don't know how many of you pushed out the bushings to replace them with poly bushings but is sucks and it sucks even more when when the dust boots on the ball joints get messed up and/or torn or the ball joint has a little slop in it and you have to replace the entire control arm. I'm on my third control arms now because of the ball joints wearing out. I understand that the N/A control arms are not as strong as the TT arms and ball joints are slightly different. The arms on it when I got my Supra were the N/A control arms. I replaced them with N/A control arms that my local Toyota dealer had in stock and did it myself. The ball joints had some slop in them in less than an oil change. I then went back to the dealer and got the TT arms and I put those on. About 6,000 to 7,000 miles later the ball joints on those went bad too. I thought maybe I just sucked at putting them on. Went to the dealer and had them put a new TT control arms on. In less than 8,000 miles those now have some slop in them. My solution for this it to modify the control arms to use press in ball joints. I'm about half way done in modifying a driver side control arm.
Here are some of the details. I looked around until I found a Toyota press in ball joint that has the same shank dimensions. I found only one. Modifications I've made to the arm so far is that I drilled out the ball joint and machined the hole to fit the slightly larger cup of the new ball joint and machine around the side of the control arm for a smooth surface. The cup of the press in ball joint that I'm using is slightly larger than what looks like the out line of where you would press out the ball joint if it were serviceable. I had to add about a 3/32" of material around the end of the arm where I had machined. I did this to thicken up the wall around the ball joint and to make it so you could use a standard ball joint press to press it in. I've also added some bracing around the sides of the control arm that lead to the hole for the ball joint. I do understand that the size of the ball can make a big diffence in the range of movement and it's ability to move properly. As of right now, I'm assuming the ball is the same size or is so close in size it will not matter. As soon as my second ball joint comes in I will be splitting it in half to compare it to the original ball. That's as far as I've gotten so far.
I still need to shave off more material from the top of the arm to hold the ball joint at the proper height and I may need to add a ring material at the base of the arm so the snap ring will fit properly. I also plan on having this powder coated black to give it a clean finish.
I will post pictures as soon as I find my usb to iphone cable, or I email some pictures to myself. The whole goal of this is to have a conrol arm that really never will need to be replaced, just serviced like any other normal car and to reduce the cost of maintence. I will be testing this out on my own Supra under rough road conditions and I do plan on trying to drift and autocross using this set up. I think this will be a great way to test it. If I works out, I will be doing this to my passenger side and possibly offering this as a service for a reasonable charge to do this to others control arms.
