I picked up a modified stock fuel rail from another SF member that has an additional feed at the other end and a center return. I had a couple questions that I was hoping someone might have an answer to. The center return is drilled into one of the bolt holes for the metal braces that hold the injectors in so I can't connect the middle brace to hold the #3 and #4 injectors in. Has anyone else encountered this and what did you do?
Also, does anyone know where to find 12mm -6 banjos? I found a site in the UK, but they're not responding to my emails.
Thanks.
Scott
Thanks.
Scott
