701 - 710 of 710 Posts
You can remove the #1 coil (leave the 4-pin connector on it) and install a plug wire between the coil and the the plug. Clamp the inductive light around the plug wire.
Anti-Socialism 2016
Can one just order the new SS springs, and if so how and how much?
Toyota Lover
Thanks for the info. Great beta testing! I will be making a new supply of GE brackets in the next few weeks and will make a couple with your suggested changes. Will swap yours for the V2 GE brackets when done.
Good morning Rick, any update on this? Still awaiting a new bracket... Mine is currently off and this would be a great time to swap it out if possible... Please let me know... Thanks!
-Milon
I have not done this yet - need to make new CAD drawings that give sufficient bracket strength while clearing the cam cover vents. Made a few preliminary designs but didn't like them. I'll try to get back on this - There has been some demand.....
I purchased the Mojo coil brackets for my 2jzgte non vvti. They are a hindrance and I would NOT recommend them if you are doing your own wiring. By design- the coil connectors face each other using this cover and are less than .25 inch apart, it's almost impossible to reconnect the lq9 pigtails once the brackets are on. They do not clear the cam cover vent tubes.
When I asked Rick- he responded that they are made so the looms go over the brackets and not under like OEM. This is a design flaw, or it should be stated on Mojo's site that the brackets are to be only used with the Mojo complete kit.
I do want to add that the Mojo retainers are high quality.
Toyota Lover
Thanks for the update Rick... Please keep us posted...
