1 - 19 of 19 Posts
I really like this shift knob and was wondering if the set screws on a good knob like this will hold without frequent tightening.
It's a Momo Anatomic Short leather knob that usually sells for around $40-45.
While we're at it, what does it take to install one of these in our MKIIIs? The stockers seem to be glued on.
I have the black leather raptor and I didn't even need the set screws, the rubber inserts do an awesome job of holding it on the lever. As for the e-brake... good luck, from what I understand those handles are model specific and if you don't have a VW or honda, forget about it.
You are in luck. I actaully own the short anatomical shifter.
The three screws WILL infact hold the shifter in pace out you need to tighten them down really well.
Also if you did the Sogi short shift mod.
the rubber insert is not tight enough to hold the shifter by itself. It has alot of play. So you do need to screw the sucker in :)
Republican
That E-brake is so SEXY I WANT THAT!
Thanks for the replies. Many of the cheap shiftknobs only have one set screw; I'm willing to pay double to have triple the number of set screws! :) Do you like yours?
Is yours fastened over the stock threads figgie? I plan to cut my shifter, weld it and sleeve it so I can maintain the factory threads. Call me weird, but I want the factory rubber isolator there.
i had a tall superanitomico on mine, set screws worked perfectly, eventually i welded on threads from the top of the shifter so i could use my trd screw on knob though....btw, first 15 bucks takes my superanitomico. oh yeah and the stocker screws off, you just need to put some muscle into it.
adam
Discussion Starter · #10 ·
Adam--if you can post pics and it includes everything including set screws, I'll take it.
I have a Momo carbon cobra knob, it's 3 allen screws to attach it. It was a real bitch to get it to stay, and it vibrates sometimes and makes noise. I'm hoping to put some rubber of some sort in it around the stick, so it won't vibrate anymore. I don't really like it, but it came with the car when I got it, so I don't care...
wrap that stick in electrical tape. worked for me :)
The first shift knob I had was the Anatomic and I found that my hand didn't fit too well on it. If I wanted to use the little spots on the knob for your fingers, I would have to move my arm in such a way that it would bump on the center console everytime so I just got rid of it.
I have the Air Race Leather or Race Air Leather now. It's just a ball with vented leather stictched around the center. It has worked flawlessly for several years now and I have not had to adjust the screws once. If you get the screws set and down there good the first time, you won't ever have to worry about it again.
When you pick it up, ask the shop for a set of the rubber inserts (mine threw in 4-5 of them and some extra screws), or take the car with you to try a few. They come in various sizes for different shifters. I just put one on the other day, and the 3 set screws, along with a snug rubber, will keep it still. The rubber is tight enough on it's own, and the set screws should just add that extra security.
Bob
Discussion Starter · #17 ·
drjonez said:
running the short anatomico on both my cars, one on a SOGI short shifter and one on a cut C's. both work fine and the set screws hold them in place. pix on my site.
Consider it ordered...
TheFastCoonAss
The vibration from the SOGI shift mod can be fixed by ordering the Green Shifter Bushings from the Toyota Pickup.
I've never found that the set screws hold good enough. I marked where I wanted the knob, then drilled a hole through the plastic spacer and into the shifter rod. I got a longer set screw and now it screws into the rod.
1 - 19 of 19 Posts
