Hey curt, this is for Travis's tranny rebuild since you got the parts in stock.
we need:
syncrho set gear 1-4
1st/2nd gear Hub assembly
3rd/4th gear hub assembly
(^so two hubs assebmly all togehter for the 4 gears)
magnet (33449b i think?)
output shaft bearing (33321A & 33321T)
speed sensor
reverse gear sensor
all seals
also we need the little ball and spring assembly that holds the gear locked in place, i have two numbers and im not sure which one it is.... 22175b&33275A, or 90080-36055 & 90080-50136 we need 2 sets of each
washers/spacer 90069-250XX? (they come in 6 different sizes, are they all the same cost? if so i will need one of each)
the nut that goes on the very end (33325-0w010)
also this part (90069-09004)
inspection plate covers (both)
and also just ONE gasket tube
and this assembly (90250-06026, 90905-62001, 33511 and the boot 33531)
we need:
speed sensor
reverse gear sensor
all seals
