Some of you might remember that a few years ago I used to make a lot of HID projector retrofit kits for MKIVs. Other priorities have come and gone since then and while I’ve been out of the game my kits, in particular the RX350 design, have been duplicated by others.
Recently, several members reached out to me in the course of a couple of weeks asking if I could design a kit to mount the new Morimoto Mini D2S 5.0 projectors. In recent years, the mounting points for a lot of projectors have begun to standardize. Thus a bracket for the D2S 5.0 projectors would also be suitable for all the NHK-G5 variants and more interestingly, the new Morimoto M-LED 2.0. The standard of aftermarket projectors has improved drastically and these units are now on par with many OEM options so seeing a niche in the market, I got to work.
I had high hopes that the design would result in a purely bolt in install however as compact as the D2S 5.0 projectors are, a tiny sliver still needs to be shaved off for correct fitment. As can be seen in the photos, this is a pretty trivial modification however. The projector then bolts in and is practically indistinguishable from the OEM unit once reassembled except for a slight blue tint to the lens.
Below are some photos courtesy of Eric AKA MKIIIHATER of an install of some M-LED projectors and Morimoto Matchbox foglight projectors into a minty fresh set of headlights using my install kits. I have got to hand it to Eric, he does some spectacularly neat work and you guys stateside are lucky to have a resource like him in the community.
OEM components.
Upgrade parts.
Installed.
All buttoned back up.
OEM components.
Upgrade parts.
Installed.
