1 - 12 of 12 Posts
The search isnt working, so I was wondering what was the most power anyone has made on a budget kit. Just trying to see what the most power someone has pushed through the stock manifold.
Lawrence
Boost4fun
A budget kit is always with a single I guess..;)
In my understanding it is a small turbo with the OE header.
Gerd
Na Zdrowie
I put down 6xx unlocked with the SP budget kit ~3 years ago. I am running a SP67GT, 4k stall, SP tranny, AEM, fuel, etc. I would have to back track and find the exact #.
Thanks for the info, Do you remember what the boost this was at? Was this the limit of the turbo or manifold?
Lawrence
Na Zdrowie
Boost was 30 psi. I am sure I could get another 2-4 psi out of the turbo if I really wanted to.
Na Zdrowie
I found this old thread when I first had my single installed. Since that installed I dumped the VPC/GCC and went AEM
Budget kit
So at 27 psi I put down 617, I know Larry dynoed my car with the AEM at 30 psi. I have to see if I can the a post about it.
Lawrence
The highest I remember on a cast manifold was from Andi; using a 67MM with a .68 housing he put down 678 whp at 28.4 lbs.
Bob G.
Kwan Jul Sul Freak
93 twintrbo said:
What I am trying to determine is how much can someone push out of the stock manifold.
Lawrence
Looks like over 600, I believe Stu Hagen flow benched it and it wasn't too restrictive up to that level.
1 - 12 of 12 Posts
