TRD3000 said:Got a motec engineer working on the car now..
The Motec has cost me near $8000 And I feel completely skint for doing it but it was the only realistic way of tuning a VVTI single supra properly with a stand alone ECU
You are absolutely correct about the VVT-i thing but the tach may be a little difficult. Since all the Turbo Supras here in the states are non-vvt-i the tach control maybe different. I know for sure that the non-turbo tachs are different from the turbo tachs. When you remove the meter trim and look at the face the non-turbo has a "L" on the face and the turbo has a "K" on the face. However, there have been guys who have installed the GTE engines into the SC300 and have been able to use the MSD 8920 tach adapter to make it work. I assume that the same can be done for the Turbo engine with a NA tach. I'm not so sure how the Euro vvt-i tach is setup since the engine does use share coils ( waste spark ). I would recommend having the Motec engineer use an oscilloscope to figure out the tach signal from the OEM ecu and try to use a digital output from the Motec to produce the tach output. You maybe able to produce any output from the Motec to the MSD tach adapter I've mentioned above and get the output from that to the OEM tach.TRD3000 said:Got a motec engineer working on the car now..
