·Has anyone used one of these? How accurate is it? What about the FJO wideband meter? anyone? Thanks.
Wayne
Wayne
SteveBoost Junkie said:I'm running a group buy on the FJO system. I have it built in my T-64 car and it works perfectly. I've already shipped the non-data-logging versions. The next shipment will be in early November and will be the new data-logging version. $665 delivered on the group buy. E-mail me if interested.
BTW, once you get used to knowing what the AFR is, you just can't imagine how you lived without that information -- kinda like getting a tach or boost gauge after not having one.Every time you make a pull, you'll find yourself watching the AFR moreso than the tach or boost gauge. It's also interesting that when you make an adjustment on the VPC or fuel controller, you can see the results on the FJO readout, and if it's much of an adjustment, you can feel the difference during subsequent pulls. With the POSSIBLE exception of a boost gauge, this is the most important item you could add to your car for tuning and safety/durability purposes.
Steve
[email protected]
So, does anyone know the answers to those questions? I don't mind paying the price but sure like know if it is any good.AZWildcat said:Remember guys, there are basically two wideband O2 sensors... Bosch and UEGO. The Bosch being less accurate and slower, but MUCH less expensive than the UEGO.
The difference between Motec, Autronics, Horiba is simply the reading unit. Is the unit heated, does it have conversions to factor in the current heat of the sensor to the reading, how fast does it update, does it have a bargraph, etc etc.
The question to be asking is which sensor it comes with...
DOOPRA said:Steve,
have you tried a dyno wideband 02 to compare to the FJO?
how do you think the Motec compares to the FJO? $1200 for the motec vs FJO $700
good job on the investigation... keep us updated
As I stated before, Horiba doesn't make the sensors! The Horiba brand name only uses the UEGO sensor, which, at your "group buy price", the senor alone would be more than this "FJO" unit...Boost Junkie said:The FJO system used the Horiba laboratory spec unit as a benchmark for performance. The FJO unit generates the same readings as the Horiba or other quality wideband systems. You can use the Horiba or other wideband sensors on the FJO controller if you feel the need to spend more money or feel it gives you some bragging rights.You will have to splice the wires though, because the connectors are different.
Don't do it.sonik said:I currently have a vpc, dsbc, and have been thinking of getting a motec, which could replace my vpc, dsbc and the need for me to get a afc
So what's this about the "same reading" again? At least be straight forward with these people man...
Here is the classic MKIV "if it isn't the most expensive possible thing out there, it must suck" attitude. Do you look at results of testing or just price tag when you select a product? He said it matched up perfectly with the Horiba system (which is several thousand dollars at last check). But FJO must suck because the Horiba is more than three times the cost? SIGH.AZWildcat said:As I stated before, Horiba doesn't make the sensors! The Horiba brand name only uses the UEGO sensor, which, at your "group buy price", the senor alone would be more than this "FJO" unit...
Grant said:Steve, do you find that AFR remains the same regardless of outside temp, humidity, barametric pressure, gear, etc?
