i am planning on buying this motor that this guy built and he wants me to make an offer on it..he will not give me a price, so i need help on determining what price i should offer.
it is a Aristo JDM 2JZGTE
about 2K to 3K miles on it
It's non VVTi, has a cast Toyomoto single turbo manifold, and a T61 with 0.69 A/R
(never dyno'd but estimated to have 700-800rwhp)
Short Block Buildup
JDM Head (no EGR)
Cooling System
Fuel & Ignition system
Intake, Turbo & Exhaust
this is the list that gave me of all his costs overall
JDM Engine Buildup...........Parts.................Labor..........................Total
Original Motor cost..............$2000...................$0...........................$2000
PolyDyn Coating..................$436....................$0............................$436
ShortBlock.........................$1115..................$1040......................$2155
Head.................................$1920..................$2475......................$4395
Fuel..................................$1849...................$175........................$2024
Ignition.............................$601....................$0............................$601
ECU & Sensors....................$2372..................$0............................$2372
Turbo...............................$3015.................$0............................$3015
Misc Parts.........................$2806.................$0.............................$2806
TOTAL..........................$16114..................$3690........................$19804
i have a FULL list of all parts/work that has gone into this engine in pdf. and xls. form if anyone would like to look at it because what i have listed isnt everything that has been done to it
hope someone can give me an educated guess on what to offer.
thanks,
Heath
Short Block Buildup
Decked & trued (one corner was approx 0.008” high)
Bored .020 over for JE forged pistons & JE rings
Piston crowns heat shield coated, and skirts oil retentive coated
Pistons & rods individually balanced to 0.5 gram, then matched & rebalanced to 0.5 gram
Clevite “H” rod bearings, oil retentive coated
Clevite main journal bearings, oil retentive coated
ARP studs on mains & ARP bolts on rods
Oil pump modified, internally coated, and Mocal prelube system added
OEM oil cooler & thermostat removed & replaced by Mocal thermostat/sandwich adaptor
Long TruCool plate & frame oil cooler in driver side brake duct
Oil shed coating on oil pans
JDM Head (no EGR)
Ported and flowed by Faerman Racing Engines
Manley SS valves, springs & titanium retainers
HKS 256/264 camshafts
Toyota MLS head gasket
ARP undercut studs & nuts
JUN adjustable cam gears
Cooling System
PWR Radiator
SPAL 16” Electric Fan (thermostatically controlled by AEM)
TRD 165 degree Thermostat
850cc Blitz injectors (cleaned & flow tested by RC Engineering)
TWM Induction Fuel Pressure Regulator
Modified stock rail (dual -6AN end feeds, center -6AN return, heat shield coated)
OEM fuel pump with Kenne Bell Boost-a-Pump (AEM PWM controlled from 9v to 16v)
OEM coil on plug ignition system with HKS Twin Power DLI booster module
4” intake with K&N cone filter
Garrett T61 turbocharger with 0.69 A/R turbine housing & BoostLogic exhaust blanket
Turbonetics Racegate, 9# spring, with Apex’i solenoid valve (AEM controlled)
HKS type S Front Mounted Intercooler
HKS SSQ Blow Off Valve
HKS TRAC removal kit on TB
Intake manifold Teflon coated internally and heat shield coated externally
Toyomoto cast exhaust manifold, wastegate flange ported to match Racegate. Internally smoothed & relieved. Heat shield coated internally & externally
3 ½” custom downpipe & SS flex by Performance Motorsports, heat shield coated
thanks,
Heath
