Mine snapped perfectly into place. I had to dremel out a little slit of plastic in the spot where it had to be mounted in the dash because the little black tabs on the trac button don't line up with the spot on the right , but it fits perfectly and does snap in. Did you pull your dash off yet? Once you take off the dash and take out the trac button you'll see how it fits. It's very easy to do. It took me a whole 2 minutes.s14roller said:its currently sitting in the slot all the way to the right. It doesnt exactly click in and when u push the trac button, the whole trac button slides back into the dash.
and just like home rocks said ,ill have pics in a day or 2 if you want when my dash is apart.HomeRocks said:Mine snapped perfectly into place. I had to dremel out a little slit of plastic in the spot where it had to be mounted in the dash because the little black tabs on the trac button don't line up with the spot on the right , but it fits perfectly and does snap in. Did you pull your dash off yet? Once you take off the dash and take out the trac button you'll see how it fits. It's very easy to do. It took me a whole 2 minutes.
Tony
