·Mr Kenyon,
I'm the proud new owner of a 94 MKIV. However, I've been experiencing some speaker audio problems The problem began with intermittent audio on the two front speakers. Currently, I've lost all audio on the two front channels.
The problem then spread to the rear channels. On power up, the rear channels work fine, but after 2 to 3 minutes of operation, the rear channel begins to fade, until there is no audio output at all. Kind of sounds like a thermal problem on the rear channel, but I'm not sure if I should beging at the amp (wherever it is) or the haed end.
I thought perhaps, the problems I'm experiencing may have been experienced by other Supra owners, and the culprit component(s) identified.
Also, if there is a link or some info you could copy to me on the MKIV basic system layout, and component locations, I'd greatly appreciate it!
Rich L.
Rich L.
