1 - 9 of 9 Posts
7m > 2jz > 1jz
whats really the difference between the two?
and does anyone have any pics of the stock manifolds side by side or at least some pics period. of both.
thanks
-sean
ƒ=1/2π(√k/m)
Different housings,wheel sizes, the WG ports... some other stuff.
What are you thinking about doing?
the 3sgte Ct26 turbo is smaller than the Supra CT26 as to what "mk3brent" stated.
It might run right......?
its also twin entry on da mr2 and the supra is single entry the exhaust into the turbine that is
Destroyer of Turbos
/\ correct. you can use the supra ct26 on the mr2 as an upgrade but not the other way around. i have talked with ats about this alot and trying to get the ct27 to work on the supra and they said 1 it wouldnt be worth it and 2 it would be horrendiously expensive. what happened to that huge turbo you had your eyes on before?
7m > 2jz > 1jz
Discussion Starter #9
no no no i dont want to use the turbo off one, i want to use a t3/t4 ive got avaliable from a friend here, but the only t3/t4 addaptors i can find for the ct26 manifold flange are from 935motorsports (but ive been told alot of the things he has on there are'nt really there for sale) and a t3/t4 to ct26 addaptor for the mr2's thats why i need to have some pics of both manifolds side by side or at least a place where i can get a supra ct26 manifold side flange or a whole t3/t4 to supra ct26 addaptor.
can anyone help me now??
thanks
-sean
1 - 9 of 9 Posts
