1 - 19 of 19 Posts
well, my FPR is leaking from the screw. so it's time to replace it. i was wondering if anyone has any feedback on the MSD adjustable FPR? Horsepowerfreaks.com sells it and MSD is a legit brand, so i'm gonna order it tonight, 'cause i need it and i'm sick of my car smelling like gasoline. plus it's a waste of gas at $3/gallon. so yea, just lookin for some feedback.
thanks, t3d
1991 1JZ
ive only ever used the aeromotive FPRs and they have always worked flawlessly. they are relatively cheap also.
relatively cheap is like 60 bucks more than this one. but i'm still lookin though
I Love Lamp...
Whats the adjustability range? You have to make sure you are not buying something for a low pressure carb'd motor...
MSD Fuel Pressure Regulators(86-92)
Fuel pressure regulator by MSD. MSD universal fuel pressure regulator is adjustable from 36 to 45 psi with a flow rate of 9.2 to 10.5 gallons per hour. The MSD universal fuel pressure regulator inlet and outlet size is 5/16" and a jam nut is supplied for special threads on the bottom to ease mounting to a bracket. The MSD fuel pressure regulators are free standing so they don't have to be mounted directly to a fuel rail and can be installed in any position. Fuel pressure is set with and adjusting bolt and is locked in position with a locking nut. The MSD fuel pressure regulator allows the tuner to fine tune the fuel pressure to meet the demand of the engine and injection system.
that's the HF.com description of the item
JZA70 448 rwhp everyday
well are u NA? If so thats probably fine, but if u are turbo or plan on adding one get a FPR that has rising rate capability so it can increase FP as boost rises.
~scott
Now with 0JZ
~scott
Uhh, personally, I would never run a rising rate FPR on a vehicle. That's just a band-aid approach. Get a real fuel management system.
That's my opinion though.
stock is rising rate...
No One Ever Listens To Me
why not spend 5 dollars to get a stock replacement....
i dont think you realize you cant just bolt an aftermarket regulator on...youll spend another ~$100 on fittings and lines. seems like a waste of time and money for a NA
I Love Lamp...
Rising rate FPR is good for 99% of people here...
If you are stock NA there is no reason to go aftermarket, plus like Ideal said, you need lines and fittings. Theres no gain involved with this.
Discussion Starter · #11 ·
hmmmm
well, i checked NAPA to see how much a stock replacement would be(figuring it would be cheaper than TOYOTA) and it was a hundred bucks. i didn't check out TOYOTAs price, but i assumed if it's that much there, TOYOTA would be more. it is an NA, but if i can find a stock replacement, i'll probably pick that up. i guess i'll have to see what a pain in the ass this is gonna be. =0(
-t3d
I Love Lamp...
Just grab a working used one... people cant give them away...
Discussion Starter · #13 ·
i wouldn't trust a used one
exactly i was gonna ask if the wtb or fs section was broken lol
why wouldnt you trust a used one? lol they arent exactly parts that break all the time...infact i was surprised to see you said yours was leaking... lol
Discussion Starter · #15 ·
lol i'll call up toyota and make sure the price is what i expected. me and my Freedom Ford dealership discount and all. =0)
I Love Lamp...
Maybe its just the O-ring and washer? If it does have one where it screws into the rail... never looked at an NA one, but it should have an O-ring or gasket of some type.
Now with 0JZ
I think people are confused at what rising rate means.
By rising rate, I'm talking about a FPR that raises fuel pressure at a ratio other then 1:1. Yes, stock FPR raises fuel pressure 1psi for every psi of boost, and vice versa for vacuum, that's what a FPR does. By rising rate FPR, I'm talking about a FPR that changes the rate at which it increases fuel pressure. eg: [email protected], [email protected], etc. Raising fuel pressure other then 1:1 with manifold pressure. I'm pretty sure the stock one DOESN'T do this.
he's an NA anyways so he doesn't need a rising rate...
I'm seeing about $100 for an OEM one (betcha NAPA is getting it directly from them)
Discussion Starter · #19 ·
i get what you guys are saying, but have anyone ever tried to use one of the MSD FPRs at all?
1 - 19 of 19 Posts
