1 - 7 of 7 Posts
Automotive Technician
Hey guys I have an MSD 6AL Hooked up right now with the tach adapter that msd offers for toyotas(8910-EIS i think) It is coupled witht a new dizzy cap and rotor and msd super conductor wires and iridium IX plugs I hooked the msd Up correctly with a Blaster 2 coil and all appropriat connections but i still have a fluttering tach. If anyone has experience working with this ignition on an MKIII please let me know how i can get my tach to not bounce around at idle.
All I can say is double, triple check your connections and the instructions. It seems you fell for a bunch of myths by buying all of that MSD stuff and Iridium plugs, especially if your Supra has a distributor. Worse case scenerio I say move everything back to new OEM stock the way it was meant to be built and engineered.
im sorry but despite your opinoins i have had this setup work on my two previous cars( 1989 Dodge Daytona ES and a 1990 Toyota Celica St) and have worked great: better performance, better idle, and slight boost in fuel mileage. and I did all of my connectiomns right with using butt connectors and the such I did not just buy this stuff because of myths. It actually works like adventized. I ahs the msd laying around and i bought the plugs and wires because it needed them and i decided to do the msd because i had it. Basically the car drives and performs better now, and all i want to do is figure out why my tach bounces around at idle.
This Is Why I'm Hot.....
Hello S.S.,
If the engine runs fine, then incorrect or faulty tach adapter; or the wiring may be at issue. For best ignition performance, I'd recommend soldering/heat-shrinking the connections instead of standard butt connectors. If you don't want to solder, there are also anerobic wire splicers availble that utilize conductive gel.
Good luck!
I contacted MSD About my problem. Here is what they suggested:
Sir,
If the tach settles down it sounds like you are getting some electronic
noise in the system. Use some dielectric grease on both ends of the
plug wires and use a VERY thin coat of it inside the cap on each
terminal. This will help that problem.
Thanks,
MSD tech
Now where can i get some dielectric grease from?
1 - 7 of 7 Posts
