you do not need have any tach adapter in sc300 with 1jz engine.anyone know which wires to tap on the ecu and behind the cluster for my 92 sc300 with 1jzgte with automatic ecu?
1. remove your stock sc300 cluster
2. remove rear white plastic panel from cluster
3. look at printing board and find resistor that is named: "R 109"
4. bypass that resistor (simple single short wire, resistor can be left there, not need remove it from printing board, just simple bypass it)
your stock sc300 tacho should work fine.
Jerry
so your saying connect a wire where one end goes to the resistor and the other to the IG on the ecu? well as of saturday i hooked up my safcII and im using that as a temporary tach but im use to using a analog tach instead of digital.Try this first take a long wire and connect one end to the tack and the other to the IG- on the engine check connector . If your tack has R109 bypassed it should work if not the msd won't work ether .
Good luck
