1 - 3 of 3 Posts
I just got a multimeter to test batteries, but just wondering what about electrical components in the engine? I know this is a pretty broad question, but what are some important things that I should test and how would I go about testing. I'm not expert with it, and I just want to get some experience with using it with more than just batteries. Thanks, anything would help out!
i guess if your just bored you could test your TPS and ISC valve, to see if they they are withing spec. check out the tsrm and test some some random electronical crap if you want to
One thing to keep in mind is when the TSRM specifies using an analog MM, you need to use an analog MM. This is usually the case with sensors with alot of fluctuation in the signal you're testing.
1 - 3 of 3 Posts
