1 - 20 of 75 Posts
Boost Creep
Thought I'd post these up for you guys:
Engine
BL67DBB (Precision) Turbo
HKS 264 Cams
HKS 720cc Injector's
HKS Carbon Ti Exhaust
Fual dual pump Denso fuel system
Greddy 4 Row Intercooler
Greddy Manifold
HKS Wastegate
HKS custom fuel rail
Electronics:
HKS VPC
HKS EVC6 BC
AEM AFC NEO
Other
Aem UEGO Wideband
Defi Boost Gauge
Defi Fuel Pressure
Aeromotive FPR
Tial Q BOV
98 Tail lights
98 Head Lights
Project Mu Brakes
Eiback springs, bilstein struts
Misc polished greddy intake piping/IC
T4 Turbo Blanket
TRD Strut Bar
New Maintenance
Timing Belt, Waterpump, Hydralic Tensioner, Cam Seals, Valve cover gaskets
Coolant Flush, engine, radiator, toyota red coolant
18 new injector seals
New tbolt clamps
New Coolant temp sensors
New Thermostat
Boost Junkie
Nice numbers! Like the other guys is asking, what was your boost pressure and what fuel did you use?
Thanks,
Steve
Boost Creep
That pull is on C16, didn't get a chance to dyno it on pump. Were hoping for 560-570.
Stock Block/Head, all I have is the cams in there. That's @28PSI. I'm VPC limited right now.
Boost Creep
Discussion Starter #6
How big is your exhaust and A/R housing on the turbo?
.81 for exhaust. I wanted to be able to push more power, so i didn't go with the .60.
With the DBB, the spool is very good.
Boost Creep
Discussion Starter #9
Super Moderator
Very nice numbers!!!!! You are not limited at 28 psi with a vpc :) Please stay with setup you got and dont fall into the "have to go stand alone" or " will make more power with stand alone" BS. Keep it simple and stay vpc...TRUST ME!!!!!! Vpc is good to 1000cc injectors and almost 1000rwhp.
Boost Creep
Discussion Starter #13
THANK YOU!! EVERYONE and there mother wants me to go AEM. I keep getting crap about how I'm using ancient technology, bla bla. Why are you even bothering bla bla.
I want to go E85, and I cant with VPC though. I also cant pull timing with the VPC?
VPC isn't meant for over 30PSI I thought?
THE VPC/AFC COMBO STILL WORKS!!!
Boost Creep
Discussion Starter #15
nice #'s, the A/F ratio is dead on with the vpc/afc. why screw with a good thing?
That's what I'm thinking. It's all in the tuner :)
Boost Junkie
Yes, great numbers and I agree with Silver Bullet, don't go AEM or standalone. The VPC is working magically and it safe and reliable at your power level. I bet you'd hit over 700 with a couple lbs of boost. Nice job.
Steve
That graph looks sweet as hell. Gotta love the 67 for sure. I am also interested to know at what PSI the VPC maxes out at (especially with the newer billet turbos now out). Congrats!!!
Now...Whitesupra94
Excellent numbers! Makes me feel good about my turbo....but that I should've went with the .81
How old is your motor...and what is allowing you to rev to 7500?
The sensor I believe is good only to 30psi, but you can always bump up the fuel pressure if you are goind lean above 30psi.
BTW awsome #'s man. The stock ecu +vpc always have a place in my heart. LOL.
congrats,great numbers. on your list of mods ,you dont mention having a gforce ecu, or any mods done to your ecu. what did you do that allows you to rev past the stock 7000 rpm rev limiter
1 - 20 of 75 Posts
