Greetings
Hope someone who has had this problem can help.
My 88 NA Supra auto trans, pulls slowly to the right above 50mph.
I have had new tires, front and rear alignment by two places.
Both say the front end is OK, not damaged, dont need any parts.
The Alignment shop says the supra meets specs for alignment.
The car pulled right before I got tires, still does.
The reason I got the tires is because they wore abnormally in the front and I dont want to do the same again. Bridgestone stock size tire.
Has anyone run into this problem, if so, where do I look to have this corrected. 130k on vehicle. Steering rack new, but pulled right prior to its replacement.
Does the car turn more when you give it gas?
The air pressure is all OK?
The ride height -- is it fairly even all around, or does the car sag to one side? (not likely, but maybe the car is always parkes sideways on a hill or something)
Mr. 2JZUL8R
time to replace ur HID tailight fluid! its causing the prob! i know it!
if u live in OC, check out SoCalSupras! i hold weekly meets and garuntee we can figure it out for u in a few mins! ;)
