1 - 13 of 13 Posts
BOOBIES
I have no idea what happened but the deck was working perfectly one minute, then I get out and shop for 30 mins, come back, and the deck is no longer reading the cd inside, and when I press eject it acts like there isn't a cd inside! I even tried holding the eject button which usually forces the cd out, but it's almost like the cd has been swallowed...
Anything I can do before I send it back? I am going on a 12 hour drive tomorrow and I REALLY need my music!!!!
BOOBIES
Discussion Starter · #2 ·
Problem solved. I went into the deck and forced the cd out of the bastard. Now it works fine! Just to let you guys know in case you ever come across this problem!
BOOBIES
Nono mine isn't that new. It was just a really fluke thing. It works fine now. I don't mind if I gotta rip the deck out once a year to get a cd out that was jammed. Just thought I'd let you guys know it's a pretty easy fix (at least with the non-brand new models).
happened to me i turned off the car and turned it back on and wala
i have the exact same model
BOOBIES
Magic: I tried restarting the car many times. Nothing happened :(
Spoonie: What is RMA?
Let's go Phils
On all alpine radios there is a reset button, it is either on the bottom left by the knob(usually) or bottom right. You got lucky that the cd eject mechanism didn't get broken. I am an alpine dealer in delaware, and they have been known to refuse repairs due to physically damaged components. just a little fyi.
BOOBIES
Discussion Starter · #10 ·
Good to know man!
Thanks a lot :)
-Aaron
040 hardtop turbo
RMA is return merchandise authorization i believe.
WI-FI FTW, GTFO fuse box!
fyi... USE NEEDLE NOSE PLIERS!!
  • Like
Reactions: Eggy
BOOBIES
Discussion Starter · #13 ·
Alrite already with the pliers!!!!!!!! :blah:
Thanks though
1 - 13 of 13 Posts
