At the very least I'd probably change the oil, and maybe give it a few cranks without starting it to get things circulating a bit.
Some people may recommend changing all fluids?
I agree with both above. I have always put a teaspoon of oil into the cylinders if i knew the car wasn't gonna be started for a while. And i always add another once the car was finallly ready to be started again. It is an old school thing my father has done with all his classics since i can remember. But be sure to crank it for a bit without allowing it to actually start to build pressure and get oil up to the head before you get in doing some major rpms. Plus depending on how much fuel was left in the tank, you may want to either drain and fill it, or just top it off with some new fuel.Pull the plugs and squirt oil into the cylinders to lubricate the rings. Pull the EFI fuses and give it a good 10 seconds of crank to build oil pressure.
thanks guys for all the help... I have owned at least one supra for the past 10 years... I have just never had one sit for this long
my main concern was about the gas, it has been sitting with probably a gallon in there for the past year.
It'll be fine. Even the gas in the tank will probably be fine, but if you top off the tank it will almost certainly be good to go. I'd drive it for 30-45 minutes, then change the oil and not give it another thought. I've routinely let vehicles sit for months at a time and never any issues. According to my experience, the conventional fears about letting vehicles sit are way overblown.thanks guys for all the help... I have owned at least one supra for the past 10 years... I have just never had one sit for this long
How have you been man, and why havn't you been driving it?
Have I talked to you since I got my single turbo 6spd MKIV?
