so exspensiveSpoolme said:well if you plan on doing anything over 300 hp you might wanna get something better than stock.
you could get like the stage 1 spec clutch. cheapest i know of is.
www.jscspeed.com
do you know how much just the clutch by it self cost?Toph said:I got a spec stage 2 with installation for 400 brand new, gotta love knowing a mechanic
A stock PP and stock disk will hold 400 rwhp/tq. A stock PP and 6 puck will hold a little over 500rwhp/torque.kylefoto said:Like to get the best bang for my buck, and cheapest if possible, on a very tight budget.
Great!Clifton said:A stock PP and stock disk will hold 400 rwhp/tq. A stock PP and 6 puck will hold a little over 500rwhp/torque.
Ya I got the clutch at cost 40% off, it was like 235 i beleive?kylefoto said:do you know how much just the clutch by it self cost?
Hopefully my mech will price it as good as yours.
kylefoto said:Great!
thanks for the info man.
PS.
That is one SICK ass 240. 7m swapped into it too?
:bowdown:
Same thing here. My clutch is starting to give up since i turned the boost up. And i'm still on the stock ct-26 :wtflol:Wreckless said:My experience differs in that my stock clutch gave out at about 320rwtq, and was not heavily worn or improperly broken in. I think your numbers would be legit for a 2500lb car but not a 3500lb MK3.
Thats what happend to me. I am using a spec 2 and I like it.dallas_wrx_blue said:Same thing here. My clutch is starting to give up since i turned the boost up. And i'm still on the stock ct-26 :wtflol:
I think weight does play a small part in it but I have dynoed at both power levels were weight doesn't matter. When I did have slippage with both setups it always started in 4th gear, both times at only 2 psi more than I ran on the dyno.Wreckless said:My experience differs in that my stock clutch gave out at about 320rwtq, and was not heavily worn or improperly broken in. I think your numbers would be legit for a 2500lb car but not a 3500lb MK3.
kylefoto said:So, any suggestions as to what I should get?
Racing, performance, brands???
it's an 89 turbo, and it's my dd.
